Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-22-2008, 03:51 PM
Vopezy Vopezy is offline
1991 98 No start
i have a 1991 ninty eight, i had it stall at a stop light. i noticed the fuel pump went out. i replaced it and im still having troubles. i've replaced almost everything since i bought the car. eg. coil pack, wires, and now the fuel pump. theres fuel pressure and a spark. it cranks over but i can't get it to run at all. is there any other major problems that i should be aware of?
Old 06-22-2008, 06:25 PM
maxwedge maxwedge is offline
A990 racer
Re: 1991 98 No start
How much fuel pressure? will it start with carb cleaner sprayed into the intake?
Old 06-23-2008, 12:50 PM
Im getting 40 to 50 psi and it holds. i let the key sit in the "run" position for about 20 minutes with starter fluid in the intake. starts right up now, everytime. Thanks.
It was only running on 4 cylinders. spur of the moment.. i put a new coil pack in... still only running on 5 cylinders. #3 isnt running.
The Coil pack gets really hot on the top square, cooler at the bottom one. it melted the green protectent on the Ignition Control Module. a computer chip is visible.
Could that make it not fire, or a ECM problem.
Old 06-23-2008, 03:22 PM
A990 racer
Did you replace the ign module and coil pak as an ass'y?
Old 06-23-2008, 04:02 PM
no, i just changed the coil pack alone.
Old 06-23-2008, 07:31 PM
A990 racer
If the ign module showed signs of melting insulation and/or overheating why was it not replaced?
Old 06-23-2008, 10:42 PM
Didn't notice until replacment of coil pack, could that be the problem?
Old 06-24-2008, 02:52 PM
A990 racer
Yes, as I said before.
