Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-22-2008, 02:48 PM
brody1 brody1 is offline
Late ignition fire
I have a 96' aurora which takes about 4 sec of turning the enging over before it fires.... I have just replaced it with new plugs and wires and still has the same effect. any possible solutions to my proble would be gladly appreciated Getting terrible gas milage anywhere between 16-20 in town
Old 06-22-2008, 06:22 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Late ignition fire
Best thing to do is check the fuel pressure and make sure it is in specs. Also, did you replace the fuel filter? Long starting times can be caused by a weak fuel pump, fuel pressure regulator, or the check valve located in the fuel pump assembly.
Timeslip 08/12/06
AF Community Guidelines
Old 06-29-2008, 01:43 PM
I have replaced the fuel regulater, and filter... and i guess that leaves the fuel pump? and i was wondering does the check valve come with a newly rebuilt fuel pump or is that a seperate purchase?
Old 06-29-2008, 01:46 PM
crash_1333 crash_1333 is offline
Exclamation Re: Late ignition fire
your car might be out of time alittle tru checking your timing and if your timing is good try your fuel delivery
Old 07-02-2008, 03:23 PM
ghutchin ghutchin is offline
As far as I know the timing on our cars is not adjustable.
Before you replace the pump make sure you take a fuel pressure reading. If its 40 psi or above it is fine.
If you are experiencing hesitation under light load while driving in addition to the hard starting you might have a dirty EGR valve.
How many miles do you have on it?
Old 07-02-2008, 07:01 PM
I have 200,000 on the engine and i have also notice when the engine warms up it also has a surge in it. i have run the engine up to 2,500 rpm to see if if there would be any notice in fuel drop and it remained steady.
Old 07-03-2008, 04:52 PM
DigitALL DigitALL is offline
I had a similar problem and could not pass the emission test. I have replaced the plugs and wires and passed marginally. I was told to use injector and valve cleaner fluid and things will improve. I have 197k so it is kind of normal to have clogged injectors.
