Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-22-2008, 10:39 AM
ericceballos112 ericceballos112 is offline
my car wont start
i have a 2001 chevy impala i changed my thermostat and throttle body gasket the car turn on right away and after about 5 or 10 min it just turned off and now wont start up again what can i do to fix this
Old 06-22-2008, 11:03 AM
maxwedge maxwedge is offline
A990 racer
Re: my car wont start
Welcome to AF. what engine #1 and do you have spark and fuel pressure?
Old 06-22-2008, 11:22 AM
i have a 3.4 i have a half a tank of gas and i the car trys to turn over but just doesnt start
Old 06-22-2008, 11:24 AM
what is the easiest way to find out if i have spark and fuel pressure
Old 06-22-2008, 03:41 PM
A990 racer
Pull a plug wire off, insert a screwdriver into the wire end, hold the plastic handle and hold the metal end about 1/8" away from the block and have someone crank the engine, see if you have a good blue/white spark jump across the gap. If ok, spary carb cleaner or a small amount of starting fluid into the throttle body see if it kicks over.
Old 06-26-2008, 12:56 AM
tsmorrisracing tsmorrisracing is offline
also if you were using 7% ethonal you might want to look a the fuel filter and
pump because if the filters clogged with water "the ethonal has water in the
mixture" you will have to replace it. And the pump might be rusted all to hell
so you might want to replace that.
