I have a 94 lumina apv with a 3.8 and need help. I need to replace the ignition switch, hopefully that is all. Does anyone know how and can send me the instructions and schematics on this. When I get this done this thing has got to go!
Re: Ignition switch
Is this switch in the column or on the dash like my wifes Malibu. If on the column you have to pull the steering wheel. Also do you mean the electrical or won't the key turn part.
Look at a Haynes manual you will need pictures as you work. |
Re: Ignition switch
Ignition switch (the electrical part) is seen as 43 on this drawing
www.avigex.ca/xport/steeringcolumn.jpg located in the lower column section. ..lock cylinder to OFF lock position remove screw and hex nut remove dimmer switch assembly from rod remove dimmer and ignition switch mounting stud remove ignition switch assembly from actuator assembly
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
