Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-21-2008, 11:05 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Slave extension
I just put in my new clutch and it looks like I am going to need to get the slave cylinder extension rod, but wanted to check just to make sure.
So I put a new clutch in. On the new pressure plate, the fingers are positioned more towards the engine than the tranny (if tha makes sense) in comparison to the old PP. Basically, after the slave adjusted there wasnt much travel left on the rod. It has alot longer to travel before the TOB reaches the pressure plate. Theres nothing else wrong with the system, the PP is just made differently, where the fingers are more recessed than on the old unit. I noticed this before I put it on.
Anyways, I tested the clutch with the car off the ground. After bleeding it thoroughly and adjusting the pedal, it just doesnt release all the way. And I was just wanting to make sure that this would fix my problem.
http://www.extremepsi.com/store/cust...cat=691&page=1
Thanks
vanilla g
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-22-2008, 12:02 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Slave extension
When I was looking into getting one of those extension rods, I read some info I can't remember the details but that there were some issues w/ using the longer rod. I can't remember the issues or how common they are but if you give it a try then let me know what it does for pedal feel.
Old 06-22-2008, 12:33 AM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Slave extension
i used the extension rod for a good 400-500 miles before my gst spun a bearing and i didnt notice any difference in engaging-disengaging, Maybe i didnt bleed it right i dont know. I always wondered, was i suppossed to bleed it with the short rod and then just install the longer? or install the longer rod and the bleed it, this is what i did but i kept thinking that it would of been better if i bled the clutch with the shorter rod and then install the longer one and leave it like that.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 06-22-2008, 01:30 AM
ned032002's Avatar
Re: Slave extension
It probably wouldn't make a difference since the only thing that changes is the distance the rod pushes the TOB, so the "plunger" moves the same distance in the cylinder. If anything, you might be better off doing it w/ the longer rod that way it creates more pressure for bleeding.
Old 06-22-2008, 07:55 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Slave extension
If my understanding is correct on the situation, the extender rod makes the clutch engagement move up in the clutch pedal travel. I'm not 100% on this, is that true? I was actually just coming on to research the extender rod and braided line, so good timing VG.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
