Old 06-21-2008, 09:24 PM
rjeffreeze rjeffreeze is offline
02 Windstar Cam Synchronizer Replacement
Alright, bare with me. I am a first time poster here... But, I am a faithful Windstar customer as I am currently driving a '98 and my wife just totaled our '03. Hence, I am now the proud owner of a new-to-me '02 with ~85k on it. That's my story.
So, regarding the '02 (3.8L)... After having mis-diagnosed the chirping as related to the alternator, I took it to the Ford dealership to have the problem diagnosed. They assured me (for just $40) that the culprit was the cam synchronizer. I have read quite a bit on this forum about replacing the synchronizer, but I still have a few questions:
1) One thread said to get the #1 cylinder at TDC and then clock the crankshaft another 26° or 27° (I can't remember which). Others (along with Mr. Haynes) said nothing about additional clocking. So my question. How do I get #1 to TDC? My only idea is to take out a spark plug and poke a screwdriver in while someone turns the crank pulley from the bottom. But please tell me there is a better way! And if I do need to clock the crank another 20+°, how do I accurately do that?
2) Next question: If after I'm done, the engine starts and seems to run well, have I succeeded? It seems that if the timing is a hair off, either gas mileage or performance will suffer, right? How do I know if I got it just right? Should I be this paranoid?
3) Will I need to remove any of the ventilation duct work to pull the synchronizer straight out? It looks like it could be in the way, but I'm hoping I'll just have to remove the water pump tube.
4) Is there any chance of damaging or somehow rendering the oil pump inoperable during the procedure?
If anyone has photos or some other documented procedure, that would be great. Sorry for being so long-winded!
Thanks! Ryan
Old 06-22-2008, 09:48 PM
CnlK CnlK is offline
Re: 02 Windstar Cam Synchronizer Replacement
Remove pass side front tire to gain access to dampner/crank pulley. Scuff dampner with sandpaper to find timing marks. Disconnect battery cable and all that safe stuff. Remove camshaft position sensor from top of cam synchro. Now, while rotating crank clockwise you'll know #1 cyl is at TDC compression when the rotating vane approaches the "window" in the synchro housing, the vane rotates counterclockwise if I remember correctly, and the timing mark on dampner aligns with pointer. On the 2000 model I removed the cowling, removed the coolant tube that enters the water pump. This was time consuming as tube was seized in pump, there was also a 2nd mounting tab for tube at PS pump. Remove serp belt so PS pump could be unbolted & held to side, now there will be room to pull synchro. Note direction that vane turns when pulling synchro. When synchro is pulled, the shaft that drives oil pump should stay with synchro, pull and install on new unit. If you have alignment tool, install on new synchro and reinstall. Synchro timing will be correct, if you don't have alignment tool, take some measurements or make your own alignment marks, I recommend the tool available for $20 to $30. Some aftermarket manufacturers provide tool with purchase of snychro. Cam position sensor provides PCM with info for timing of fuel injection system. Hope this helps.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
Old 06-23-2008, 09:04 AM
pitteach pitteach is offline
I used the alignment tool when I replaced mine. I did not worry about lining up with #1 TDC. I took off the cam sensor and put the alignment tool on the old synchronizer. I rotated the engine until the tool lined up with the synchronizer. There is an arrow on the tool which I marked on the top of the block. I removed the old synchronizer, put the tool on the new synchronizer, and lined up the arrow with the mark on the block. The synchronizer shaft will rotate when it lines up with the gear on the oil pump, if your off the mark, lift it up and try again. As long as you keep the tool locked on the synchronizer, you should hit the mark. At worst, you will be off by a tooth or two which will be very noticeable.
Stay away from the cheap replacement from Dorman Inc. It is Chinese and poorly made and I've heard bad things. I used a remanufactured Ford part from Cardone. If not, get one from the dealer.
2005 Nissan Quest 3.5S
2000 Windstar LX 3.8L
1990 Nissan Pickup 4X4 3.0L
Old 06-23-2008, 09:37 AM
12Ounce 12Ounce is offline
I agree with both the above posters. But I find Pitteach's approach simpler. I will try to add a couple of observations that make the tool unneccessary:
1. Since your engine is currently operational, we can assume the synchronizer is currently timed OK. So all you have to do is observe the current relationship of the "wand" to the "window" ... and get the new synchro set up exactly the same. You could use a digital camera to help the memory. You don't have to worry about "TDC", "clocking the crank", none of that stuff ... but you do have to make sure that the crank is not rotated during the removal/reinstallation procedure.
2. Remove the sensor. Observe and record the wand-to-window relationship. Remove the synchronizer. (The oil pump is not a concern ... even though the shaft drives both the oil pump and synchronizer.) Install the new synchronizer with the exact same wand/window relationship as the original synchro. (The new synchro body may not end up in the exact same location as the one removed ... it may be twisted a bit ... they just don't make the synchro's that identically.) Install the sensor, etc.
You should now be "good to go". (I've used this procedure. I've also used the tool. Both methods are OK.)
Old 06-23-2008, 07:43 PM
Slightly rotating the crank then trying to get the alignment tool to drop into position on existing synchro is a good idea. I also tried that, on my van the synchro timing was actually retarded. The alignment tool would not drop until I was about 8 degrees ATDC. When I reinstalled synchro I repositioned crank to TDC and dropped in synchro with alignment tool. Without actually confirming dampner timing marks you are assuming the existing timing is OK as 12 ounce mentioned. If you ever had any timing cover work performed or are unsure of vehicle history, synchro timing may be off. I think there is even a TSB on the matter, so some may have been off from the factory as I suspect mine was.
Old 06-23-2008, 09:36 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Will routine engine washing cause the Synchronizer issues?
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 06-23-2008, 09:40 PM
With all the stuff mounted on the front of the engine, it is very difficult to get a direct line of vision to the timing pointer on the front cover ... and my pulley/dampner markings were almost non-existent. Could they have made it a little more difficult? I actually first measured piston travel, and then re-marked the pulley, to get some useable markings.
Old 06-23-2008, 09:48 PM
Good question about the engine washing, Ed. I can only say I lost a synchronizer and had never washed the engine that I can remember. But I do think hi-pressure washing could contribute to failure. Its probably a good idea to occasionally lift the sensor and drop some clean oil drops in the top of the synchro. Just my guess.
Old 07-08-2008, 11:18 AM
Welp, I replaced the cam syncrhonizer this weekend. It fixed the chirping noise. You could tell that it was the probelm just turning it by hand. It also had some black dust/filings that appeared to be the result of friction in the bushing/shaft. I did end up using the tool from OTC, and didn't worry about getting #1 to TDC. In fact, I had no idea where to look for timing marks on the damper/crank pulley. If anyone has some pictures or a diagram, I'd be curious to see it. It seems to be running well now. However, when I first started it, it made a grinding noise. Hopefully, it was just the water pump running dry for a minute as a result of disconnecting the inlet tube! I drove it around a bit and everything seemed normal. Just fyi, I originally bought the chinese made part from NAPA for $45. I returned it and got the Motorcraft part from Parts Plus for $115.
Old 07-08-2008, 11:37 AM
Glad your problem is resolved, however I suspect the timing of the synchro may be off if you didn't find #1 TDC. Did you do as was suggested, slowly rotate crank until alignment tool would drop onto orginal synchro, then drop tool on new synchro & install new synchro? You should be OK if you used that procedure, but if orginal timing of existing synchro was off, it would still be off. To find timing marks on dampner, scuff entire circumference with sandpaper, marks will be faint. The only way to view pointer/mark relationship is with the pass tire off and your head up in the wheel well.
Pointer is part of the timing chain cover. Marks on my dampner were three longer marks with intermediate marks. The long center mark should be TDC.
Old 07-08-2008, 08:56 PM
Yes, I used the method that you described. I didn't remove the old synchro until the tool dropped in. So, my timing should be the same as it was before (right, wrong, or indifferent . Just to clarify, the damper is the rusty steel disk just behind the crank pulley right?
Old 07-10-2008, 02:51 PM
Using the method you described, the timing of the new synchro would be the same as what the original was. Yes, the dampner is that rusty object behind the crank pulley, there are timing marks on it but they probably won't be visible unless you scuff up surface with some sandpaper.
Old 11-21-2008, 01:39 PM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Question Re: 02 Windstar Cam Synchronizer Replacement
Would this procedure be the same for the 1995 3.8L?
Also, I have a new engine so I should be able to see these timing marks easier huh?
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 03-05-2009, 09:31 AM
TheRealGrizeg TheRealGrizeg is offline
so how do i reinstall this thing is i didnt get a tool and was stupid enough not to pay attention to how i took it out. cause that the story of my life...
Old 03-05-2009, 09:57 AM
Freakzilla69 Freakzilla69 is offline
I replaced my Camshaft position senser in my '98, turns out, it wasn't the sensor. Somehow the top of the synchronizer got bent and it was destroying the inside of the sensor.
I can't offer any advice on installation, I took it to a mechanic for that, it wasn't very expensive.
