Old 06-21-2008, 08:26 PM
ned032002's Avatar
ned032002 ned032002 is offline
Brake/Clutch Fluid
What is the best fluid to use in a clutch line? There are several different kinds of fluid but i want to know which kind is the best to use. I found these on Extremepsi.com. The reason I'm asking is because I reinstalled my slave cylinder after thinking it was bad and I just bleed the heck out of my clutch and everything seems fine now. I asked a very knowledgeable dsmer and he told me that the reason that I lost all pressure in my lines was because of air getting in them that was caused by the fluid boiling. So I would like to prevent this from happening if possible but I don't know what kind of fluid to get. Any suggestions?
http://www.extremepsi.com/store/cust...cat=782&page=1
Old 06-22-2008, 11:20 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Brake/Clutch Fluid
The only way I can see air getting in the line is if you do in fact have a leak and the resivoir going dry. Regardless, having air in the lines shouldnt cause it to boil I dont think, but the air itself is compressible, which is why you didnt have pressure. Check the lines and make sure the slave cylinder isnt bad, and be sure to keep an eye on the fluid level. As far as fluid, I think any of them should be fine.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-22-2008, 11:57 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You cant boil your clutch fluid. You cant create enough heat to boil it. There is some other problem going on here. What were you doing when the car lost pressure?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-22-2008, 12:32 PM
ned032002's Avatar
I noticed that when I drove the shit out of the car the clutch pedal between shifts would feel like there wasn't much resistance. It felt like the resivoir was empty, I had that happen in my Talon back in the day and if felt just like that. I didn't try bleeding the line till after I pulled the slave cylinder off and then I reinstalled it almost a month later. I checked the Slave cylinder for a leaky plunger but it looked fine. I'm repeating what I was told.
check this out
http://www.rangeracceleration.com/Clutch_Care.html
