Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-21-2008, 05:19 PM
ibernie ibernie is offline
1996 Rodeo Won't Start.
I just bought a basket case Rodeo. Looks like it had some wires chewed up by a mouse in the dash.
I have a Check engine light on.
Scan Tool will not read the computer.
Fuel Pump Runs.
Drained half the fuel out 5 gal and added fresh fuel and some seafoam.
Car cranks but but only attempt to start on Wide Open Throttle. Seems to fire but will not actually start.
I have fixed broken wires I found.
Checked all fuses.
How do I determine if I have a bad computer or Crank Position Sensor?
Any Help will be greatly appreciated. Thanks, In advance.
Bernie.
Old 06-22-2008, 08:35 AM
FL 3.2L FL 3.2L is offline
Re: 1996 Rodeo Won't Start.
Curious to know how things look under the timing covers.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 06-22-2008, 01:28 PM
I havent looked under the timing covers...Do I need to?
I thought I was chasing an electrical problem preventing Ignition or Fuel.
I did remove the CAM Position sensor and noticed that the cam was turning so I fiquered I did not have a broken belt.
PS the car has 144,000 mi on it. I have no history on the car. Thanks.
Old 06-22-2008, 03:14 PM
Air, fuel, spark, timing.
Do you have spark?
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 06-22-2008, 04:41 PM
Because of the coil pack being unfamiliar how do I check spark. Do I pull off the coil pack and sparkplug. Then ground the Sparkplug to the engine?
Old 06-22-2008, 04:45 PM
One more troubleshooting point of reference...
At the MAF Sensor I am getting 12v to the Yellow Black wire to ground.
5v to the ref wire to ground.
The unusual thing is with the plug removed I am getting 36ohms to ground from the blk\ylw wire. That seems like a direct short to ground.
Any Ideas?
Old 06-24-2008, 06:47 PM
No Spark...Any Help? I do have voltage to the coil packs
