Old 06-21-2008, 01:14 PM
jmas jmas is offline
97 Taurus A/C Charge Port Replacement???
The High Side A/C Charge Port Valve does not seal correctly and leaked out all the gas. I want to replace the valve but I need to know if it can be unscrewed from the A/C Line? The Port does have a Hex on it but it is hard to turn and I don't want to break the line. Any Suggestions would be Appreciated. Thanks
Old 06-21-2008, 03:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 97 Taurus A/C Charge Port Replacement???
usually the valve inside the port is the problem. It unscrews like a valve stem core. Just be sure to replace it with one for an a/c system.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-22-2008, 09:55 AM
The valve does not appear to be a Schrader type. It has a spring loaded ball visible in the fitting. It looks as if the whole fitting must be removed.
Old 06-22-2008, 04:29 PM
way2old's Avatar
TOKEN HILLBILLY
This what you got??? If so, the entire valve can be replaced.
In the two-piece design, the aluminum top portion of the valve is threaded to the bottom part and sealed with an O-ring seal. The valve seal is an integral part of the aluminum fitting piece which must be replaced if the seal leaks.
Old 06-25-2008, 01:49 PM
Smile Re: 97 Taurus A/C Charge Port Replacement???
Thanks for the Help - The fitting did unscrew from the A/C line. I did however, have a problem locating the part (Even from the Ford Dealer) but ended up at the local salvage yard and took one from one of the numerous Taurus vehicles in the yard. A great benefit of owing an older Taurus - inexpensive used parts availability.
