Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-08-2003, 06:38 AM
sirrach sirrach is offline
Getting power to the ground?
It seem like I'm not getting enough power to the ground, I'm spinning out at launch a lot. I got new pirelli tires which helped a little, but what else can I do to get more grip and power down to the ground?
Old 03-08-2003, 11:11 AM
del del is offline
móddə rąytər
what kind of suspension setup do you have? you can install urethane suspension bushings and even polyurethane engine mounts/inserts to help get more power to the ground. but if you do so, your ride will be noticably rougher and with the engine mounts/inserts, the car will vibrate quite a bit at idle. but once you start going, the vibrating goes away.
Old 03-08-2003, 12:41 PM
I have a 92 si 4ws that is mostly stock.
Old 03-08-2003, 01:31 PM
del del is offline
móddə rąytər
get a stiffer shock/spring setup. that'll help. also like i said, urethane bushings. almost all FWD cars have traction problems when you have a lot of power. and even when you do upgrade the suspension, you'll still lose some traction on the launches. even the stickiest tires can slip. practice, practice, and practice. the best way to minimize it is through a good suspension setup and grippier tires.
