Old 06-21-2008, 04:52 AM
EF1_163 EF1_163 is offline
Auto Transmission fluid Qs, please help!
I have got a JDM 91 1.3 carb civic with auto transmission, I noticed that there is jerking when downshifting and it has a bit delay when i shift up, is it because of transmission fluid?
Also when i checked the transmission fluid, its way above the indication of the dipstick, its above the FULL sign, should i drain some out?
Old 06-21-2008, 05:15 AM
Re: Auto Transmission fluid Qs, please help!
I said the indicator is above FULL, its when the car is cold, it has not been driven.
Old 06-21-2008, 05:33 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Your supposed to check the fluid level while the car is running.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-21-2008, 05:35 AM
OKay, but does it supposed to go above the FULL level when its hot?
Old 06-21-2008, 11:19 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
When the fluid is cold, it could well be above the indicator... what you should do, is drive the car around for about 10 mins, making sure you go through every gear the tranny has... that includes backing up, 1,2,3,D, etc.
Then stop and check it with the engine still running and the transaxle in either Park or Neutral.
Old 06-21-2008, 04:39 PM
right, so after its been through all the gears and the engine is hot, what level does the tranismission fluid gonna be in?full?above full?
Old 06-21-2008, 05:35 PM
dan89 dan89 is offline
if it's hot it should be at the full mark, as said before check it with the engine running, and trans in neutral or park
click for my cardomain ^
Old 06-21-2008, 09:16 PM
above full can damage your transmission, it will build too much pressure trying to move the fluid... too low can damage it by not lubricating/cooling it enough.
at or just below full is best, and if you have to drain some, might as well change the filter and fluid, and add some lucas transmission fluid stabilizer to it... that will help recondition the clutches and allow for firmer, more positive shifts.
Either that, or just use Royal Purple ATF... helps get more power to the wheels...
Im not a salesman, I'm just familiar with these products, and they work. Period.
