Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 06-20-2008, 09:55 PM
h.olen h.olen is offline
1995 G-20 conversion van
iam having trouble with starting the and keeping it running i a bad sensor oxygen ther are no other code in the computer ihave replace vacuum lines.distributormcap and rotor. and wires. could it be the fuel pump or tbi.sny help will be appreciated. thanks
h.ole
Old 06-21-2008, 09:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 G-20 conversion van
What engine and engine codes?
Have you tested the fuel pressure?
What code no is it setting?
MT
Old 06-21-2008, 09:34 AM
angus10 angus10 is offline
Fuel filter I'm thinking.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 06-21-2008, 03:27 PM
MT-2500's Avatar
AF - Advisor
In reply to your PM.
It is best to keep answers and question in you post so everybody can help.
We need to know what engine.
The code 44 you mention in pm e mail is not need 02 sensor code.
Codes do not say replace sensors, but to check it out.
Code 44 is lean exhaust code.
On a 4.3 or 5.7 engine
Fuel pressure bad wiring on 02 sensor or weak sensor or exhaust leak or water in fuel or clogged fuel filter.
Also make sure the tank has over a 1\4 tank of fuel.
To check fuel pressure hook a fuel pressur gauge to the scrader valve test port if it has one or hook inline at the fuel filter and be sure to check the fuel filter.
Post back fuel pressure readings and what engine.
MT
