Old 06-20-2008, 06:38 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
car giving me problems
alright here's the senerio...
it will not start after being driven for a long distance. i thought it was the distributor and went ahead and replaced it since it needed to be done anyways, but that didn't seem to fix the problem. recently happened today, drove car to a friends house and went to start it and nothing...turn the key and get nothing...power comes on but nothing happens when i turn the key. i waited an hour and it started, which is what i usually have to do...could it be the starter?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-20-2008, 09:19 PM
readallen readallen is offline
Re: car giving me problems
ignition switch or starter solenoid, most likely starter safety switch
Old 06-20-2008, 11:19 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
There are 3 things it could be. I would check the simplest first..as it has happened to BOTH of my civic and probably everyone at one point. Also it the reason I got my car for 350 :P. The starter safety switch on the clutch. Youll find it up under the dash. push it in and try to start it. Other than that, its either the ignition switch, starter relay, or starter itself if all the wires check out. Those are the ONLY parts in the circuit. If it was a fuse it wouldnt start ever.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-21-2008, 11:21 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
I'd say safety switch as well... possibly solenoid.
If it's the switch, you can remove it easily... I assume this is why my LX didn't have one in it when I bought it.. b/c it probably wore out or wasn't adjusted, and someone took it out.
Old 06-22-2008, 07:05 PM
BLU CIVIC's Avatar
調整器
I'll check those...should i check it when it won't start?
The name's Adrian
2011 CR-Z - Stock
Old 06-23-2008, 05:03 PM
Basically, if it doesn't start, try reaching under the dash and pushing that switch back with your finger before you start it... if that doesn't work, pull the wires and install a jumper between them, and if it starts, the switch is bad... same process for the other stuff.
You can get your solenoid tested by pulling the starter and running to AutoZone... they'll check it for free.
Old 06-24-2008, 07:29 AM
BLU CIVIC's Avatar
調整器
i tried to find the switch yesterday when i waas stuck at autozone...i'm going to have to buy a manual
The name's Adrian
2011 CR-Z - Stock
Old 06-24-2008, 12:28 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Its right above your hood release, not up there like the main relay is.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 06-24-2008, 02:15 PM
BLU CIVIC's Avatar
調整器
ok i'll take a look today
The name's Adrian
2011 CR-Z - Stock
Old 06-24-2008, 02:44 PM
FrodoGT's Avatar
Well the switch is actually at the top of the clutch pedal up by the cable linkage. the relay is directly behind the hood latch.
Current project:
Rio Red 91 hatch.
Old 06-24-2008, 03:04 PM
Tony's Avatar
TLD Member #1
Oops, yea, Frodo is right. Switch is at the pedal, relay is above the latch.
Tony
Old 06-24-2008, 07:43 PM
easiest way to find it is to follow the clutch pedal arm all the way up to the pivot joint, and it will be behind the pedal in the back above the pivot joint.
Should be a white thing w/ a "normally open" circuit momentary contact switch.
