Old 06-20-2008, 06:37 PM
lesabrefan lesabrefan is offline
Help with fuel level sending unit replacement
Dear all!
I got my fuel level sending unit (for the posessed fuel level indicator) and installed it, as was wonderfully explained here on the forum. Everything worked fine for about a month, the sending unit went bad and I got a replacement from the seller. After I replaced the second one, i started to smell gas in the car and after a while I got "Gas lid not closed" message, along with the "Service Engine Soon" message. Basically to make the long story short, I realized that I did not tighten the ring that holds the gas pump tight enough. When I open the lid in the trunk, I can see that there's gas coming out of the tank, after the drive. I hammered the brackets that hold the metal ring as tightly as I could and the gas still leaks out when driving. The funny thing is that I did not tighten the brackets as tight the first time and everything was fine and now...
Please help - don't know what else to do.
1996 Lumina 3.1 - 191K
2001 LeSabre Custom - 153K
2006 Explorer 4.0 - 55K
Old 06-20-2008, 07:48 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Help with fuel level sending unit replacement
The big "O-Ring" under the the top of the flange will need to be purchased at the dealer. Many of the aftermarket seals are too thin and will leak!
Old 06-20-2008, 08:10 PM
HotZ28, thank you for the response. The O-ring is original, I did not replace it. Can the ring lose its "holding power" over time?
Old 06-20-2008, 08:37 PM
HotZ28's Avatar
AF Moderator Elite
Yes, if it is original, more than likely it has flatened out and has lost it's "holding power"!
Old 06-20-2008, 08:41 PM
HotZ28, thanks again for your help. Will hit the dealer tomorrow and will let you know the outcome.
Old 06-23-2008, 02:10 PM
HotZ28, hit the nail right on the head. I went to the dealer and got the o-ring for 18.21. Took out the old one, it had an inch long impression on the ring, that prevented ithe ring from being snug. Replaced the ring and vuala - the gas stopped leaking. Two days later, while driving both "Loose gas cap" and "Service Engine Soon" messages dissappeared, the gas tank got repressurized.
Thanks again for the help.
