Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-20-2008, 02:38 PM
monteheeren's Avatar
monteheeren monteheeren is offline
Axle Replacement
Working on a '95 Town Car. The car has air springs and needs the rear axle replaced. Can I remove the rear axle without removing the air springs? From reading the repair manual, it says you need a diagnostic tool to re-inflate the air springs. I do not have that tool.
Monte
Old 06-20-2008, 05:38 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Axle Replacement
No diagnostic tools needed to inflate the springs. Make sure you turn off the system before jacking the car.
Follow this process and you'll be fine:
http://www.lincolnsonline.com/tech/00003.html
-Steven
1996 Town Car, Cartier
Old 06-20-2008, 08:14 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
R u replacing the axel shaft or the whole axel with houseing?
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 06-21-2008, 12:00 AM
Steven , Kit1993,
Thank you for the reply. I am replacing the entire axle assembly. Real good friend of our church drove up from Nashville and his axle snapped in two.
Have the old axle out. Will try the procedure from Steven. Sounds like it should work!
Monte.
Old 06-22-2008, 01:12 AM
Steven,
Your post work perfectly! Thank you very much for the info. It saved me a lot of time. Have the new rear end in and the air springs inflated. Yea!
Monte
