Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-20-2008, 04:45 AM
shooter_va's Avatar
shooter_va shooter_va is offline
A/C Question
I re-charged the system about 8 or 9 weeks ago and the A/C was doing fine for about 6 weeks. The front started to blow a little warmer when used alone but did OK when running together with the rear A/C. This week it wasn't cooling anymore - there must be a leak somewhere so I took it to the dealer. They said that the was pretty much out of Freon, so they re-filled it, put in some dye and searched for a leak: Nothing. The condenser is fine and the compressor shaft seal as well. They used a sniffer and the black light and told me to run the van for a week with the A/C on and take it back to them for another leak check (free of charge) since it might be a very slow leak. They also mentioned that the evaporator core could leak? They would try to check this with a sniffer (due to accessibility) upon return of the van. Is this a possibility?
Here is a link to a previous post: http://www.automotiveforums.com/vbul...d.php?t=895073
1998 Venture LS
2001 Silverado 2500HD, LT
1990 Cavalier
Old 06-20-2008, 05:03 AM
reekor reekor is offline
Re: A/C Question
Evaporator core leaks are very possibile.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-20-2008, 11:57 PM
rockwood84 rockwood84 is offline
Re: A/C Question
ever seen the valve core leak on a tire ? these can leak on a/c systems too and most people don't know to look for this .any of the seals and o rings in the a/c system can leak . also rear a/c has another 15 foot of lines to look at plus the o rings on it.one other place to check is at the hoses that connect to the a/c compressor if the hoses wiggle then the hold down bolt has pulled out of the aluminum threads in the compressor. easy fix with a longer bolt.
