Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-19-2008, 06:14 PM
Adventurer_96's Avatar
Adventurer_96 Adventurer_96 is offline
96 Trailer Wiring Question
My 1996 has a hitch but the trailer wiring connector was cut off at some point.
I've got five wires, white/black/green/light green/orange if I remember, and I've got a 4/7 dual connector to wire.
Is this a standard wire group for the trailer? Or, do I have to go through and test each one.
Would it be lights, brake, turn? What else?
Thanks...
Check six.
Old 06-22-2008, 08:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 Trailer Wiring Question
White Wire = Ground
Brown Wire = tail and park lights
Yellow Wire = Left turn
Green Wire = Right Turn
Red wire is for Auiliary Trailer wiring stuff.
Blue Wire = Electric brakes
But always check them with a test light or volt/ohm meter.
And be sure to seal all connections and tie in's with a sealer to keep moisture out.
Best to solder wiring splices.
The quick connectors or butt connectors trap moisture and damage wiring and cause major headaces.
Good Luck
MT
MT
Old 06-22-2008, 09:59 AM
777stickman 777stickman is offline
To add to MT2500 description:
RED wire is battery power.
Lt Green wire is back-up lamp power.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-25-2008, 08:26 AM
Thanks for the replies, gents. I found out I've got to wire the truck for a brake controller so I just had a local shop wire for the controller and install this connector.
Check six.
Old 06-27-2008, 01:09 AM
Change one... I'll be doing the wiring myself since the shop's prices are over the top and I don't trust them to do it right.
I bought a brake controller today from Wally World and the extra wire to hook it up, as well as a soldering iron and heat shrink, but it looks like the boy threw the whole bag in the trash.
Back to square 1...
Check six.
