Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-19-2008, 05:49 PM
Leon722 Leon722 is offline
Question 1995 GMC Jimmy Key less remote
How do I program a keyless remote for my 1995 GMC Jimmy?
Old 06-19-2008, 10:37 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: 1995 GMC Jimmy Key less remote
Welcome to the site. Drop the kick panel on the driver's side under the steering wheel. You will see the black keyless entry box. Using aligator clips or a bent paper clip, jump both posts on the red connector thats not connected to anything. Your doors will cycle and you will be in programming mode. Press and hold the OPEN button. When the locks cycle again, the remote has been programed. Do the same for each additional remote. when all remotes have been programed, remove the jumper on the red connector.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-20-2008, 10:07 PM
Unhappy Re: 1995 GMC Jimmy Key less remote
I used your advice, and what I found was an after market key less remote box which has no red connector to jump. It seems the previous owner to my Jimmy had some electric work done, and the original remote key box is gone. Any ideas on how to proceed next?
Old 06-25-2008, 09:14 PM
ZL1power69's Avatar
GM S-Series Mod
If its an aftermarket unit see if it has the company's name on the unit and try to contact them. Otherwise its almost imposible to determine how to program it.
Low 11 sec sleeper
My Cardomain
