I replaced coolant sensor and now the temperature guage is not working. Checked all fuses, now ok.
What is going on? Thanks. Ducky2b |
Re: 93 coolant sensor
Your car has two sensors. You need to replace the one with the 2-wire connector as this is what the PCM uses. The one with the 1-wire connector is what the dash is based off of. Be sure both are corrosion free.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man |
Thanks. ducky |
Check your connectors. They must be corrosion free. Replace them if needed
Can you tell me where the 2 coolant sencers are ,I've got sort of the same problem.
thanks |
