MAP Sensor
Hello. I lent my vehicle to one of my friends and he said that the MAP sensor needed to be changed. I was just wondering, what would a bad MAP sensor cause? what problems would i notice? is it worth changing? does it have anything to do with idle/hesitation? thanks!
2002 Oldsmobile Bravada AWD w/ SmartTrak 1999 Mitsubishi Galant 2.4L I4 |
Re: MAP Sensor
Do not even think may be this or that or listen to freinds advice.
Do not start throwing parts at it. Proper testing is the way to go. Start with a code check and post back code no. Check fuel pressure and primary ign system. How many miles on tune up?
Re: MAP Sensor
Re: MAP Sensor
Ac-delco plugs?
What is fuel pressure readings? Camshaft retard readings? Fix that exhaust leak. Before throwing parts at it get oit on a good engine capable scanner and check things out. If any past/history or present codes or missfires in history post back MT
