Old 06-18-2008, 10:16 PM
dksram
Guest
Posts: n/a
To DexCool or not to DexCool? That's the question.
I went to check the fluid level of the radiator on my '98 S-10 pickup and noticed that the water/coolant was black.Yes BLACK.Not brown or orange but BLACK.
I was going to flush the system includind the block but was wanting to know one thing. Should I replace the coolant with Dexcool or can I use standard coolant?
The truck has 168,000 miles on it and going strong.I purchased it with 160,000.When my duh huh ex-mechanic serviced the truck,he never mentioned that coolant. I assume he was tired or in a hurry.
Lat dollar spent there.
Any suggestions on the coolant would be helpful.
P.S. I have read all the good and bad about dexcool and I can't decide.
Old 06-18-2008, 11:51 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: To DexCool or not to DexCool? That's the question.
Did you read this article about Dex Cool? http://free-auto-repair-advice.blogs...label/Dex-Cool
Some good points are made there to continue using Dex Cool as it was specifically designed for your engine and internal parts. Much of the "issues" blamed on Dex Cool has been linked to improper / lack of maintenance of the product. I continue to use Dex Cool in all my GM vehicles in which it came in with no problems, ( The only problem I had was a faulty intake gasket on a 3.4 and this was poor quality gasket material, not the Dex Cool's fault. GM has since issued a revised gasket.) I flush and refill my coolant based on the maintenance schedules for the old ethylene glycol based (green) antifreeze. I'd thoroughly flush out all the old coolant from your engine, making sure you try to get most of it out and refill with Dex Cool and then continue to service it on a regular basis.
One more thing. The old standby green coolant does not offer the same protection packages for your engine as the GM approved coolant Dex Cool.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 06-27-2008, 04:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Not to mention that the old green antifreeze contains silicates, which can wipe out the bearings on your water pump. Older water pumps were designed to cope with this, newer ones aren't.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-27-2008, 08:24 PM
Dr_Rock Dr_Rock is offline
Thanks for posting the link I have been trying to research this issue for the last couple weeks as my car manual says to use the Dex-cool.
Old 06-27-2008, 08:34 PM
Blue Bowtie's Avatar
Registered Offender
Originally Posted by '97ventureowner
... I continue to use Dex Cool in all my GM vehicles in which it came in with no problems,
Ditto here. I've even changed over my '86 and '94 to DexCool, and have stopped eating heater cores every two years in the '86. Maintain it properly, and you shouldn't have any problems. Check concentration, pH, and conductivity/TDS once a year, and change the coolant if the numbers get out of spec or it is five years old. It is imperative to keep air out of the system to prevent solids precipitation and the resultant sludge formation that everyone blames on DexCool.
Old 06-29-2008, 12:32 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Only problem with the s-series cooling system is that its not air tight and dexcool is suppose to be used in air tight systems. It really needs to be serviced just as often as std green coolant.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 07-02-2008, 03:29 PM
brandon200317 brandon200317 is offline
i have my 96 and haven't had an issue with dex.. i would just go with what is recomended for you vehicle. as for it being black.. have you checked your head gaskets? black coolant could be a sign of oil getting in to the system. my parents just had a 97 astro blow a headgasket and it was dumping alot of coolant into the oil.. needless to say it died for good.(RIP)
Black 01 silverado LT z71. 5.3L extended cab.
Black 2000 Mercury Mystique LS, 2.5 v6 5 speed.
