Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-18-2008, 05:32 PM
mannasugar mannasugar is offline
Ignition problem
92 Camaro
Randomly starts with key. When the car will not start with the key,
I use a jumper wire to crank the engine over. Engine cranks over ( starter is not bad ) ,
I am getting spark from the primary coil wire while using the jumper wire, I am not getting fuel using the jumper wire.
Somewhere between the Ignition switch and the Throttle body injector wires is the problem.
What are the steps taken to test the Ignition switch?
