Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 06-18-2008, 03:42 PM
misio66661 misio66661 is offline
Problem with lights on a dashboard
Hey guys. I have a question. I have Chevy Monte Carlo '98 V6 3100, and I have a little problem. There is no lights on a dashboard. I'm not sure what could cause that. Could it be a fuse or something like that? How can i find out what's going on with those lights? Any suggestions? Thanks.
Old 08-23-2008, 08:14 AM
sierra77 sierra77 is offline
Wink Re: Problem with lights on a dashboard
I had the same problem with my '96 LS when I bought it three years ago. Mine would flicker every so often, so I knew that it was something other than the fuse. I figured out that it was the actual headlight/dimmer switch. My buddy works for a Chevy dealership and told me that even with his price, the switch is over $80. I decided not to go that route since mine was a work car, and I didn't want to put that amount of money into little things like that.
I studied the wiring diagram in the back of my Haynes manual and bypassed the dimmer portion of that switch. So now my dash lights all work, but are all on the full brightness. I don't mind since I never dim my dash lights anyways. The switch still works in the all the way up position to turn on the dome however. If you are not up for the task, I'd try a new switch.
Old 09-22-2008, 12:59 AM
sad-lumina-owner's Avatar
sad-lumina-owner sad-lumina-owner is offline
why not try a wrecker for a cheap replacement on that switch?
Finally got my dream car:
- but I can only afford one this big.
Old 09-22-2008, 01:45 AM
Scrapper Scrapper is offline
AF Premium User
do you have tilt wheel? i'm sure you do can you feel any loose play in steering colum? if not i would replace the switch if you go to salage yard if car don't have battery in it i would not buy. try ebay if you cant aford a new one. by the way is it loose? if not when you open door and look at that boot thats in between the door and finder check those wires out that run threw that rubber boot.
