Old 06-17-2008, 10:07 PM
ogier ogier is offline
Exclamation fuel problem
have an 86 camaro with a 305 carb motor all computer controlled need info on how to lean out fuel to air ratio
Old 06-17-2008, 10:40 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: fuel problem
I seem to recall these carbs received an electrical signal from the ECM which adjusted a needle and seat arrangement inside the carb. This adjustment had a limited influence on mixture.
If you wish to have a manual mixture adjustment, it may be reasonable to bypass the ECM input into the carb and use a variable resistor to provide an adjustable voltage input into this mechanism (presuming the 22 year old carb is still functioning correctly).
Alternately, go for a tuneable aftermarket spreadbore carb, like an Edelbrock (carter) or a Holley, and learn how to jet it properly.
Old 06-18-2008, 12:50 AM
UncleBob UncleBob is offline
AF -Advisor
Re: fuel problem
create a vacuum leak
might help if you offer a bit of info. Is it running rich? trying to pass emissions? Trying to improve economy? details are aways helpful
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-22-2008, 03:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: fuel problem
The computer controlled carburetors use the needle valve for controling fuel into the engine, the total amount of fuel, not just the mix. (all they are is a fuel injector without a nozzle built into a carburetor body) If you use a variable resistor, you will be able to control how much fuel the engine gets (although it should have an on-off pulse or the winding could/will burn up), but it would mean turning it while you accelerate and when the trans shifts, more work than what I would want to do. At the same time, if it does have the CCC, it will also have an O2 sensor which would mean the vacuum leak wouldn't help either.
If it's a non-CCC, then do the vacuum leak. "T" into the brake booster hose and run it to a valve inside the cab, and run the other side of the valve to the air cleaner. That way you can control the leak for when you want more fuel.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
