Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-17-2008, 09:55 PM
BigLou101 BigLou101 is offline
99 tahoe
Hi, ive got a question my 99 tahoe has about 147 thousand miles on it
every 600 miles or so i notice that my oil is about a half quart to full quart low. have checked for leaks, no smoke on starup no smoke at heavy accelertaion. i know its got quite a few miles on it. but where is it going?
Old 06-17-2008, 11:33 PM
Fresno 126 Fresno 126 is offline
Exclamation Re: 99 tahoe
Hi,
It depends on wich motor you have. If it is teh 5.7 v8 it is most likly stuck oil rings on one or two pistions or your possible your PCV is clogeged and not working. If it is the 5.3 aluminum V8 I would check the PCV First as it was revised by Chevorlet twice. If you get one go to the dealer and not your local parts store. If you could help me with a question i will give you a copy of the product for free.
http://www.askdatabase.com/campaigns/?af=41989
Fresno 126
Old 07-08-2008, 02:57 PM
OneBadasz71tahoe OneBadasz71tahoe is offline
Smile Re: 99 tahoe
Have you checked your Oil Cooler lines for leaks? I had similar symptoms with my 1998 Tahoe until I changed both the upper and lower cooler lines. Problem Solved.
