Old 06-17-2008, 08:01 PM
mom3inssf mom3inssf is offline
Question Odometer problems on 98 Caravan
My car has had an ongoing problem that noone seems to be able to fix. My odometer light stays on, even after I shut off the car. It is on 24/7 and as a result, I will have a dead battery if it sits longer than a day. The battery is only 9 months old. I brought the van to the shop back in January for this problem, as well as flashing lights on the fan/air conditioning panel. They replaced the ignition switch, which fixed the flashing problem but the odometer was still staying on. I just brought it back in again because I am getting tired of jumping the battery (and the lights were flashing again!) They could find nothing wrong with the system that could be causing this. They said I may need a new instrument cluster to fix the problem, and if that doesn't work, they will look into it further. My question is, can there be something else done to fix this, before I spend another $600 on this car? I would really appreciate any feedback!
Old 06-18-2008, 08:56 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Odometer problems on 98 Caravan
A very long shot but, try pulling the IOD fuse in the fuse box next to the battery. Leave it out 2-3 minutes then reinstall it. This will reset the Body Control Module which controls instrument panel functions. Not really what you are looking for but, if the odometer disappears when you pull this fuse you could keep pulling this fuse to kill the odometer until we can come up with a permanent fix.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-26-2008, 04:26 PM
brocsbar brocsbar is offline
many caravans have this problem and if you let it go your guages and spedo etc wont work. take out the 4 screws that hold on the a/c stuff and unplug it and inspect for a burnt terminal I JUST did one 5 min ago. Clean it up and plug back in or get one from the junkyard
