Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 06-16-2008, 08:53 PM
sbiddle sbiddle is offline
K-10 brake light on
This is a 72 4X4 which uses a proportioning valve in the brake system. The brake light is on and the rear brakes don't have much of an effect. Is this likely a problem with the proportioning valve or the master cylinder. Yes, there's plenty of fluid and the peddle feels ok.
Old 06-17-2008, 12:45 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: K-10 brake light on
sounds like the m/c or the rear brakes need bled more, have air in them
or the rear shoes need kicked out more
check to see that the shoes are out at the drums inside them
if they are not close enoguh then they will not come out far enoguh before the front pads clamp onto the rotors and prevent the m/c from depressing any further thus preventing the rears from grabbing hard
air in rear line will do the same thing
master cylinder rear piston seals may be bad as well
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 06-17-2008, 10:04 AM
777stickman 777stickman is offline
The proportioning valve not only regulates pressure but also acts as a safety valve. If it senses a loss of fluid to either the front or rear brakes it will shuttle in either direction to stop pressure and fluid flow where the loss is. When this happens it turns on the brake light as a warning. Sounds like this is what happened to your K-10.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-17-2008, 06:36 PM
Thanks for the advice. I did notice that when the brakes are applied the little pin in the front of the proportioning valve moves out a little bit. Anything else I can try to diagnose this issue? I'll take a look at the rear brake pads to make sure they are positioned closely when I get a chance.
Old 06-17-2008, 10:50 PM
I just checked the rear brake pads and they are properly positioned just a few clickes on the star wheel from grabbing....I'm stimied because the brake travel and feel is normal which tell me it isn't a master cylinder problem...What do you all think?
Old 06-18-2008, 09:35 AM
If there are no leaks, replace the proportioning valve.
57 Chevy 210
Old 06-23-2008, 07:25 PM
I replaced the proportioning valve and bled the brakes and no more light. It appears to be fixed. Thanks to all for your help.
