Old 06-16-2008, 06:11 PM
Smith1000 Smith1000 is offline
97 Lesabre Hard Starting
I have a 97 with just under 200,000 miles on it. Recently, it has been hard to start in the morning. It usually fires the first time, but immediately dies. Sometimes I have to crank on it and press the gas pedal slightly. It will then start and run fine/normal. It runs great otherwise.
No codes have set due to this problem. The fuel pump has never been replaced. It seems fuel related. Are there any other potential items to check? Could it be the fuel pressure regulator valve? Thanks.
Old 06-16-2008, 07:43 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 Lesabre Hard Starting
I'd check fuel pressure at start up, key on make sure it primes to 41-47 psi. Also how recent is the fuel filter, get past this and next step is a scan to look at the temp sensor input.
Old 06-16-2008, 07:56 PM
happydog500 happydog500 is offline
I had, not the same problem, but one simular. It ended up being my fuel pump. maxwege is right. You need to check the fuel pressure.
Chris.
Old 06-17-2008, 09:17 PM
Thanks. I'll check the fuel pressure this weekend. This afternoon, it started fine. The fuel pump must be getting somewhat weak by now.
Old 06-18-2008, 06:58 PM
Several people told me fuel pumps eather work or they don't. I found that was not true. On mine, after I replaced the fuel pump, I could tell it had been getting weak as time went on.
Wow! what a difference it made! I could do nice burnouts again with it.
Chris.
Old 06-21-2008, 09:54 AM
I checked the fuel pressure this morning. It initially reads 50 at start up. When running, it reads 43-44. The fuel pressure is great. There are no codes. It still was hard to start this morning. Had to press into the gas pedal. In the afternoons, it is not hard to start. I'll check the temp input sensor next.
Old 06-21-2008, 03:16 PM
A990 racer
Look for raw fuel in the hose at the FP pressure regulator.
Old 06-21-2008, 04:08 PM
No raw fuel at the fuel pressure regulator hose. Just checked it. It was difficult to start, even though the temp is over 80 this afternoon. Had to press into the pedal. I haven't checked the resistance of the temp sensor yet.
Old 06-21-2008, 06:58 PM
Is there only one temp sensor? I believe there is and it has 3 wires. The engine temp reads fine, but possibly one of the other leads may have a problem. Might try cleaning the iac and passages also.
Old 06-21-2008, 07:07 PM
A990 racer
A scan will answer that question as you will get a live sensor reading, a leaking injector is another problem, check how fast the FP drops after shutoff
Old 06-21-2008, 08:05 PM
Now that you mentioned it, FP is dropping fast after shut off. I noticed that this morning. I would bet it's a leaking injector over the temp sensor. I would expect a code if the temp sensor was acting up.
Old 06-22-2008, 07:42 AM
Temp sensor is okay. Also, I cleaned the end of the idle air control valve and the interior passage where the tip seats. I added some injector cleaner to the fuel as well.
Old 06-22-2008, 11:50 AM
Jrs3800 Jrs3800 is offline
Ok... For the L36 Series II, the fuel pressure spec is 48-55 Psi( You will idle a little lower than 48 )...
But if the system is bleeding off pressure quickly, then the regulator may be bad and bypassing the pressure back tot he tank, or the Check ball in the pump may not be seating properly causing a leak down issue...
Next time you jump in the car, cycle the ignition a few times to build pressure and see if that helps the car start quicker
Old 06-22-2008, 09:17 PM
Cycled it and it started right up, so it's the pressure bleeding off for one reason or another. It doesn't smell flooded after starting. Must be the check valve or the pressure regulator. There is no raw gas in the line though. Thanks.
Old 06-23-2008, 11:06 AM
Call your dealership and see if there is a recall campaign that covers the 97 LeSabre... A lot of these cars actually had to have the Fuel pressure regulator replaced due to the regulator leaking, also I believe that GM reflashed the PCM to help avoid any backfires through the intake...
Could be a replacement Fuel Pressure Regulator for you if GM covers the LeSabre under this...
