Old 06-16-2008, 05:01 PM
stonesample stonesample is offline
ignition 92 grand voyager
92 grandvoyager 3.3 engine , wont start no spark is there a better way to check through the ignition sysyem then replacing part after part, i figured on replacing the coil and the pickup ? anything else i might be overlooking ??
Old 06-16-2008, 07:20 PM
tempfixit tempfixit is offline
Re: ignition 92 grand voyager
Have you done the key dance to find out if any codes are present?
Turn ignition switch on/off-on/off-on within 5 seconds without starting engine, your check engine light will flash giving you codes. EXAMPLE- one flash pause flash flash means code 12.
Post back codes.
Old 06-20-2008, 04:53 PM
turned out to be short in a fuseable link there was no codes in the computer
. thanks for the help all
