Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-16-2008, 03:02 PM
camhar1 camhar1 is offline
2004 Suburban steering wheel rattle
I have a 2004 sub and when I go over a bump it feels like the steering wheel rattles.You can feel it thru the wheel. I've been in the engine compartment and played with the u joint. The shaft moves a bit.Is this normal? What could be wrong? Thanks for any insight.
Old 06-16-2008, 04:04 PM
2000CAYukon 2000CAYukon is offline
Re: 2004 Suburban steering wheel rattle
Do a search on "Intermediate steering shaft". I used the lube kit from the dealer (paid $15) and have not had an issue since. Other's have had the shaft replaced.
//2000CAYukon
Old 06-17-2008, 06:14 AM
Thanks for the info.Big help. I will do the job this weekend.
Old 06-22-2008, 10:08 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Yep, probably the intermediate steering shaft. We have a lot of problems with them in a lot of our vehicles! Before doing the lube kit, just try excersising the shaft. GM had us doing this for a while until they came out with an updated steering shaft for them. The most important thing before doing this job is to secure the steering wheel by putting the seatbelt through it and buckling it so the steering wheel doesn't spin and break the SIR coil in the steering wheel! Then take the 15mm bolt out of the steering shaft under the hood, wiggle it out of the lower shaft, then push it up as far as you can towards the firewall until it stops. Do this about 20 times, bolt it back up and it should be fine. By doing this it directs the grease inside the shaft up to the splines where it's needed. If it doesn't fix it then put the lube kit in.
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
