Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-16-2008, 02:53 PM
OneBadasz71tahoe OneBadasz71tahoe is offline
Question 2 door 4x4 with possible t-case issue
I have a 1998 4x4 2 door tahoe. It is a z71 and has the push button transfer case. I was inspecting the truck over the weekend and noticed play in my front drive shaft. The truck was in 2hi when I did my inspection. I could not move the shaft side to side but I could move the shaft (north south) or in and out of t-case to some extent by a quarter inch or so. I do not have any leaks on the t-case. Is this normal? The 4x4 functions well in hi and lo. Maybe I should check it out when the system is engaged in 4hi? Any thoughts on this one guys?
Regards,
ONEBADASZ71TAHOE
Old 06-26-2008, 09:22 PM
j cAT j cAT is offline
Re: 2 door 4x4 with possible t-case issue
Regards,
ONEBADASZ71TAHOE
there is play in this componet...this is normal...check/replace all transfercase /front differential fliuds evey 30,ooomi and look for metal and fluid discolorations...shaft play is normal...
