Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-16-2008, 12:10 AM
Figaros's Avatar
Figaros Figaros is offline
downstream O2 sensors
1999 7.4L
I just replaced my fuel pump & now my downstream o2 sensors are 99% of the time flatlining between 85 & 115 mV.
Upstreams are fluctuating as they should between 80 & 800 mV.
Any ideas?
Old 06-22-2008, 09:59 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Re: downstream O2 sensors
Did you replace the fuel filter when you changed the pump? 9 times out of 10 the reason why the pumps fail is because of a clogged filter. If it's clogged there will be low fuel pressure giving you the lean O2 readings. There could also be a vacuum leak somewhere, or an exhaust leak sucking in outside air causing the O2 sensors to go lean.
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
