Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-15-2008, 09:16 PM
abovenbeyond's Avatar
abovenbeyond abovenbeyond is offline
Checking 1991 Timing
Hello all,
Considering I just bought the car, I just changed the oil, lubed the chassis, replaced the air & fuel filter, changed the plugs, cap & rotor, and found a question when looking at the timing...When I looked at the timing tab, it looks like there is a round hole and like 3 teeth as you go further from the hole.
Where should the timing be set to? I see no numbers on the tab and have no clue what the teeth represent?
Here are my specs, I have the 305, free flow 2.5" exhaust, Automatic of course. And I am at about 6500 feet elevation.
Any help would be appreciated.
1991 Caprice Classic
Old 06-15-2008, 10:56 PM
CD Smalley CD Smalley is offline
Re: Checking 1991 Timing
Get some carb cleaner and a rag and clean that tab off. You'll be able to see the marks and numbers then.
Also, you'll need to find the EST wire, brown w/black stripe, and disconnect it. Should be on passenger side near the firewall with a weather pack connector.
Timing should be 0* IIRC.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-16-2008, 12:27 AM
I thought I remembered something about a plug, it effects the electronic timing right?
Anyways, on my engine the timing tab is behind the water pump and looks hard to reach for cleaning, it does not look so dirty, I just see no numbers or lines for that matter. Thats why I assumed the notches meant certain degrees? Do they not?
Also the tab certainly has a round hole tube like deal on one end, what does that signify?
Old 06-16-2008, 12:37 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
If you look on your distributor, you will see two wire harnesses coming out of the side. One has 4 wires and the other has two wires. The two wire harness is the power for the distributor (and, by extension, the engine), so don't remove it. Remove the 4-wire harness, which is the ESC wire. With this wire removed (ignore the service eng soon light), start the engine and set your static timing to 0. Plug the wire back in and you're set.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
