Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-15-2008, 04:59 PM
richtfan richtfan is offline
ac switch cuts off sporadically
this cuts off on the highest setting #5. it works on all the other settings. then I can switch it back from 4 to 5 and the #5 fan setting will work.
would this be a switch problem or a resistor on the blower motor?
Old 06-21-2008, 07:25 AM
baby141 baby141 is offline
Re: ac switch cuts off sporadically
Wow! I was just about to post the exact same thing. I have a 2002 venture and I've been having this problem for the last 2 years. I just took it in for service before the warranty expires. The following repair was done per my invoice but it has not solved the problem.
replaced blower resistor, replaced HVAC control module and spliced in new HVAC control module connector.
I'm still having this problem whether it is heat or a/c. I'll let you know what happens next when I take it in.
I just left a message for the dealership yesterday.
Old 06-22-2008, 01:23 AM
rockwood84 rockwood84 is offline
should be the resistor bad. but have seen bad spot on switch .try resistor first as it easier to get to.
Old 06-23-2008, 08:18 AM
how do you change out the resistor on the blower motor?
is this something I can do from the inside of my vehicle without tearing the dash apart?
Old 06-23-2008, 09:35 AM
brcidd's Avatar
brcidd brcidd is offline
Under dash above passenger footwell- remove hush panel- then notice purple and black wire that leads to blower motor- the other end attaches to infamous resistor assembly- remove two (sometimes 3) 5.5mm screws to pull out resistor- after you disconnect the wiring harness....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-23-2008, 10:43 AM
preshate it.
scott
