Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-15-2008, 02:49 PM
firebirdnta's Avatar
firebirdnta firebirdnta is offline
96 bonne se ac please help
we just filled the ac but it is still blowing hot air like the heater is on. have checked everything fuses ok, composer comes on, but it feels like its blowing heat from the motor can there be a thing in there that moves to block the motor heat and could it be stuck and if so were
If it runs, drive it
If it knocks, fix it
If it smokes, floor it.................................BOOM
opps sell it
Old 06-16-2008, 01:46 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 96 bonne se ac please help
Notice in the pics below, the heater core blend door actuator location and the failure mode common for the actuator. The actuator is located behind the glove box, on top of the heater core box. Not easy to get to!
Old 06-16-2008, 02:29 PM
wow Thanks lol had the glove box out and trying to figure out how to get in there past the air bag after seeing your pics i just stuck my hand up there and moved it. it's blowing cold now. lol but after seeing what we will have to do to fix that part I think i'll have someone else replace it before winter for now its alot cooler then it was with the windows down.
opps sell it
Old 06-16-2008, 08:05 PM
HotZ28's Avatar
AF Moderator Elite
Way to go, good job, & enjoy the cool air!
Old 06-18-2008, 07:53 AM
Jrs3800 Jrs3800 is offline
On the Bonneville you will be able to get a thumb wrench/ratchet in there to replace the actuator... Mine broke in hot mode on the way home in the rain...LMAO... I replaced it ASAP...lol... And the gear inside was broken in the exact same manner..
This replacement can be bough from Rock Auto for $40ish and change..
