Old 06-15-2008, 03:00 PM
blind60 blind60 is offline
Cool Im leaking!
Here's what I ve got: 92 K2500 5.7L 218K Miles
I bought this truck not long ago so I don't know much aobut the history. I've noticed it has an engine oil leak only after its been driven. Since its not my daily driver when it sits for a week I know that it does not leak. Only after I drive it for a while and park it will I notice it will leak for a while. Im assumeing that it's just dripping the oil that has sprayed from under the truck. This has led me to believe that my leak is somewhere higher up in the engine. somewhere above where the oil sits when the vehicle is not running. What are my most leak prone areas??
Thank you in advance for your input
Old 06-15-2008, 05:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Im leaking!
Oil filter and base and oil filter and oil cooler lines.
On the upper side check the oil pressure switch and back of intake and valve covers.
Clean it ioff good and run engien and watch for lek.
For the hard to find leaks they make a leak dye kit too put i n the engine oil.
MT
MT
Old 09-29-2008, 10:30 PM
Re: Im leaking!
I just some time to take a closer look at my oil leak.... and afte some research I believe it may be my oil filter adapter seal. I will be replacing the seal tomorrow. Ill let you guys know how it goes.
Old 10-11-2008, 12:43 PM
Re: Im leaking!
yup replaced the gasket and o ring on the oil filter adapter and it seemed to have fixed the leak. I still have some oil on the bottom on the engine but it is definitely alot better.
Old 10-12-2008, 09:52 AM
MT-2500's Avatar
AF - Advisor
Re: Im leaking!
Thanks for posting back how it went.
Sounds like you got the main leak.
If you think it is still leaking clean off all old oil and look for anymore leaks.
They make a leak dye kit for hard to find leaks.
Good luck
MT
