Old 06-14-2008, 04:18 PM
edgograbow edgograbow is offline
91 stealth front hub removal
Broke off two lugs on the front. Am having problem removing front rotor to put the replacement lugs on. Have the nut off that bolts on axle but the rotor doesnt want to come off. Is there something else (that i cant see) holding this on or should i keep trying to loosen it off.
Old 06-14-2008, 06:27 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: 91 stealth front hub removal
Do you have a twin-turbo or a non-turbo?
You don't need to remove the axle nut to get the rotor off.
I assume you already removed the caliper and caliper bracket, correct? These two things are all you need to remove to get the rotor off (actually just the bracket will remove both). The only thing that would hold the rotor on after they are removed would be corrosion. In which case you need to hammer the rotor off. You can usually break it free by hammering the raised hub part of the rotor, but if it's really stuck on there you may have to hammer from behind.
There's also the option of using two small bolts to thread into the holes in the hub section of the rotor, this sometimes works to pop the rotor away from the hub.
BUT, if you're non-turbo and you're trying to replace the studs, you're in for some dissapointment. You need to remove the hub from the steering knuckle using a press to make room to remove the studs. If you're twin-turbo then there will be bolts to remove the hub, but that requires some serious hammering to seperate the hub from the knuckle.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-15-2008, 08:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Once you get the caliper bracket and the caliper off hit the edges of the rotor with a hammer to loosen the rotor. It's most likely rusted to the HUB. If you hit the edges you'll be able to reused the rotor. If you hit it from behind your will mare the face of the rotor. Plus hitting the edges gives you the ability to hit it harder.
