Old 06-14-2008, 03:35 PM
cf1 cf1 is offline
manual trans problem
I have a 2006 silverado 4.3 with less than 30,000 miles on it. 5 speed manul transmission, Its hard to get into first gear at times, , and at times locks up in neutal, could itbe the clutch adjustment? clutch grab very close to floor. How do I adjust the clutch? any help thanks.
Old 06-14-2008, 11:42 PM
j cAT j cAT is offline
Re: manual trans problem
make sure the transmission is full....next check clutch fluid/leaks....next replace clutch....
Old 06-15-2008, 11:23 PM
cf1 cf1 is offline
Trans is full, is there an adujustment on this.. The trucks got less than 30,000 so it should be under warrant 36 0r 36. I had troubl when i fist got it and gm couldnt find anything. I a retired truck driver so its not me. seems like the older trucks that use to stuck between gears.
Old 06-16-2008, 11:22 AM
777stickman 777stickman is offline
If it has the hydraulic clutch system there is no adjustment. Check fluid in the clutch master cylinder. If it's still in warranty, dealer should make it right!!
Good luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-16-2008, 11:37 AM
kahjdh's Avatar
kahjdh kahjdh is offline
Might want to go to a lighter oil in the trans.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 06-16-2008, 01:05 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
check clutch disc wear
check for proper clutch slave or master cylinder operation
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 06-16-2008, 03:57 PM
cf1 cf1 is offline
My conclution is its the trans out of sinc. talked to a ford mechanic he said the same ting. so its back to the dealer i go. and hope they give me a loaner car. thanks guys.
Old 06-16-2008, 04:17 PM
the transmission could be defective...but the clutch could also have problems other than wear as well as the clutch control cylinder...
based on your clutch pedal it appears to me to be a clutch problem..
