Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-14-2008, 01:34 PM
Micro1 Micro1 is offline
2003 Driver Window problems
I got in my car with the windows up, started the car lowered the driver window and it made a cracking noise when it was going down. Put the window back up and while driving it went down by itself and now won't go back up. The motor is still working but making this noise like something's broken inside of it.
I took the door panel off but can't see anything, it just sounds like broken gears inside the motor.
Thanks
Micro
Old 06-14-2008, 01:52 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2003 Driver Window problems
Sounds like some of the nylon pieces on the window regulator assembly broke. A new power window regulator will probably fix the issue.
-Rod
Old 06-14-2008, 03:43 PM
-Rod
The window fell straight down fast like nothing was holding it up. So the you think the motor is still good? I'll tell my mechanic on Monday about it when I take it in.
Thanks for your help.
Micro
Old 06-14-2008, 08:45 PM
shorod's Avatar
SHO No Mo
The new window regulator will probably also come with a new motor. Expect the regulator to run you around $130 for the part.
-Rod
