Old 06-13-2008, 07:42 PM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
Hood Latch Came Off! Help!!!!!!!!
So my buddy tries to open my hood by tryin to pull the cable from the front bumper and freakin pulled off the hood release cable line. So now i cant open my hood no more. Is there a way i can still open it or do i have to take it to some kind of mechanic shop? If so, which shop? Thanks!!!!!!!!!!!!!!!!
4TH GEN CIVICS ROCK
Old 06-13-2008, 08:09 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Hood Latch Came Off! Help!!!!!!!!
Take the bumper off. Problem solved.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-13-2008, 08:53 PM
Dont you have to open the hood to remove the filler piece then the bumper?
4TH GEN CIVICS ROCK
Old 06-13-2008, 09:38 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
nope.. it's 2 or 4 bolts behind the bumper lenses, depending on model and where it was made.
then you remove the 2 screws on each side in front of the front tires.
After that, there are like 10 screws that hold the filler and actual bumper in place on the bumper cover, lined up across the top.
Oh, if you still have the drag panel (plastic) you need to take out like 4 10mm bolts to get that off too, else it will tear and hold the whole bumper from coming completely off the car.
Old 06-13-2008, 09:40 PM
guy at the shop has a kid w/ a 4th gen... he broke the cable to open the hood, so they put in a new cable, and put a Jeep door handle just under the bumper connected to the cable... so he can open it w/o getting in the car, and noone knows it's there, unless you KNOW it's there.
Old 06-14-2008, 12:10 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Yea, just pull the bumper off. Its the 2 bolts(maybe 4 as mentioned) behind the bumper lenses and 2 screws on either side holding the fender liner to the bumper, and if you do have the plastic plate under neath, unbolt that...even if you didn't unbolt that, you can move your bumper far enough down to get your hood undone without doing any damage to the plastic plate.
No need to touch the filler panel or the screws on top of the bumper. Those screws just hold the bumper cover to the support, which you don't need to separate for this.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 06-14-2008, 12:43 AM
FrodoGT's Avatar
Yeah it took me alot of head scratching to figure out how the hell to get the bumper off after owning a crx, which is different.
Current project:
Rio Red 91 hatch.
Old 06-14-2008, 05:59 PM
my 88 HF was the same way... two bolts behind the bumper lenses
