Old 06-13-2008, 01:18 PM
WayneE WayneE is offline
4channel amp help
i just bought a 4channel jl audio amp,
i know how to hook up a mono block to subs but this will be my first time hooking up a 4 channel,
ok well i will be running 4 6 by nines through it and 4 tweeters, is there anything i should know before hooking up?
would it be best to run higher gauge speaker wire through the car for best power efficiency? and do i just wire the tweeters in the same jacks as the speakers?
i really have no clue how to do it so any help would be greatly appreciated
Old 06-13-2008, 07:23 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: 4channel amp help
why the extra tweeters ?
You can use 14 Ga speaker wire and all will be right. The tweeters will need some type of crossover on them or they will blow quite quickly.
Old 06-13-2008, 08:14 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
ditch the 6x9 plan and either get 1 set of component and run them active or get 2 sets and run them passive.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
