Old 06-13-2008, 11:22 AM
jusber15 jusber15 is offline
Exclamation Crank, no start, crank then starts
2000 Chevy 2500, 6.0, 4x4. When I first try to start the truck, I can crank it all day and it wont start. I let off the key a second, crank again and it will stumble a bit but then starts. From the guy who I just bought it from, he said this started after he had the fuel pump replaced a few months ago. Any ideas??
Old 06-13-2008, 11:45 AM
j cAT j cAT is offline
Re: Crank, no start, crank then starts
if you read the many posts about this issue you will find your answer as every week some one has asked this question ....
measure your fuel pressure then with that the answer is usually a bad pump/replace filter/ check gas tank fuel pump ground at frame rail..
must use OEM pump ...most pumps made by others fail in a few months.
it could be other problems but YOU must provide the answers to what was checked what was found as it is too vague as to where the problem lies.
Old 06-16-2008, 01:43 PM
Ok, I got out there today and got a fuel pressure gauge on it. Here are my findings:
Key in the on run position: 5 psi
Key in the crank position: slowly climbs from 5psi engine starts at about 35 psi, continues to climb to 49 psi
Holds between 49 and 53 psi while revving on the engine hard
Key off, the pressure quickly falls to 0
As I said before, this is a new fuel pump, assumed to be aftermarket. New fuel filter as well.
Old 06-16-2008, 03:11 PM
your fuel pump is no good....replace with oem type not some after market type....also to be safe replace fuel filter as well. then check pressures I'm sure you'll see faster starts and pressures 55psi range with no pressure drops on shut down....let us know what happens..clean and check for security the pump ground at fuel tank on frame rail....
Old 06-16-2008, 03:38 PM
Shouldn't the fuel pressure regulator keep the pressure in the lines after the key is turned off?
Old 06-16-2008, 03:49 PM
if your injectors were leaking badly it could be that,it could also be leaking fuel lines but if its bleeding down fast and cylinders aren't flooded and you don't smell gas leak it's usually fuel pump check valve ...this causes rapid bleed down most of the time as well as low pressures...
the regulator diaphram could have a hole in it , remove vacuum line to it if it smells of gas replace regulator...
Old 06-17-2008, 11:25 AM
wafrederick wafrederick is offline
Banned
If you want to know,Carquest's fuel pumps are now made by Delphi.Carquest did the switch to Delphi and ditched Airtex because a lot of many comebacks.Never had a problem with a Carquest fuel pump since they switched to Delphi and it has Delphi's logal on the box.
Old 06-18-2008, 12:24 AM
rockwood84 rockwood84 is offline
if fuel regulator checks out then its the fuelpump........
Old 06-19-2008, 03:44 PM
Originally Posted by jv.91982
I think the guy lied to you about the fuel tank...maybe the fuel pump may be replaced with a broken one or it hasnt been replaced at all... what do you think?
many have suffered this fate....non oem fuel pump failures in a very short time....out of box even.......
