Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-13-2008, 12:13 PM
John Vinti John Vinti is offline
Air conditioner not blowing cold air even after a charge
I have a 99 Suburban with front and rear ac. It recently has stopped blowing cold air. I added 15 ozs of 134a +, up between 25 -45psi with no improvemnt. I noticed that when the compressor cycles the pressure drops below 25psi.
1. Have I recharged improperly?
2. Could there be another problem?
3. should I add more 134a +
I would appreciate any other suggestions since this was the fitst time ever I tried servicing the AC system on any vehicle. There are no other symptons on this vehicle , just lack of cold air.
Thank You
john
Old 06-13-2008, 12:35 PM
j cAT j cAT is offline
Re: Air conditioner not blowing cold air even after a charge
Thank You
john
with the windows open and the fan speed to max...the compressor should continue to run and not shut down or drop in pressure with the air temp @80deg. f...R 134 low side pressure should be at 40 psi...if pressure drops then rises add small amounts until pressure stabilizes....
where the refrigerent lines at fire wall go into the vehicle using your fingers feel for both lines to be at about the same cold temperature..
if these lines are not cold and the pressure is steady at 40psi at low side fill point you most likely have air in the refrigerent system....
don't forget to check the temperature door control as this can cause lack of proper temperature from vents....
if you add too much r134 you could damage compressor so with compressor running the pressure must never get above 50 psi ....
Old 11-28-2008, 03:07 PM
99suburban2wd1500 99suburban2wd1500 is offline
Having nearly the very same a/c problem with my 99 burb that has front and rear a/c, one small twist, the rear a/c blows cold the front a/c does not. Assuming there are check valve like assemblies, if I have air in mine, would it accumulate in the front evap? versus the rear? Doesn't seem likely to me. Do dual A/C's have two expansion valves? Perhaps a piece of trash in the expansion valve? Assumes dual a/c have two expansion valves? Do they?
Old 12-01-2008, 04:59 AM
jsnowbordr47 jsnowbordr47 is offline
check your expansion valves and/or orifice tubes. I had a problem where the system was fully charged but the back expansion valve was not functioning, so it wasn't blowing cold. The compressor should periodically turn off and on, I had a problem with another of my Suburbans where the compressor kept on running (problem with switch), and it eventually built so much pressure (I think weather also had something to do with it 125+degrees outside) that the A/C hose blew up while I was driving. So I'm thinking that it's normal for the compressor to cycle on and off.
good luck
Old 12-01-2008, 08:43 AM
brcidd's Avatar
brcidd brcidd is offline
These systems have an expansion valve in the rear- and an orifice tube just beyond the "Y" split in the front- check it. It is along side the frame rail- there is a connection right next to it to access it.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-01-2008, 09:51 PM
Cusser's Avatar
Cusser Cusser is offline
Yes, orifice tube in front, expansion valve in rear. You need to read and supply BOTH low side and high side pressures to get help, at about 1500 rpm after running a few minutes.
