Old 06-13-2008, 07:29 AM
cobraprince cobraprince is offline
Amp and switch help.
I am really new to installing amps and speakers, but I was wondering doesw anyone know how to and what rating of a switch to use to install in order to turn the amp on and off from within my passanger compartment. I have a 400 watt 4-channel amp and it is located in the trunk of my 1994 dodge stealth. Also, does 400Watt 4-channel mean I am only getting 100 watts to each speaker if I hook it up to four speakers?
Old 06-13-2008, 11:23 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Amp and switch help.
Most headunits have a control that lets you turn off the subwoofer RCAs, if yours don't, get a switch and wire it into t he remote wire. DO NOT wire it to the power wire despite what some people on this forum say, it is NOT safe. Get a switch that can handle 12-14v and a handful of amps.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-13-2008, 12:21 PM
Ok...I am probably going to sound stupid for asking this...but...which is the remote wire?
Old 06-13-2008, 07:20 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the remote wire is the blue wire with a white stripe coming off of the headunit. The amp should have a terminal place marked remote to conect it to.
Old 06-14-2008, 12:47 AM
Thank you, I got that now. And which end should the fuse go at? closest to the amp or stero?
Old 06-14-2008, 11:20 AM
Audio Guy
most people don't fuse it, however it would go on the headunit side since the HU is the one supplying the voltage
Old 06-14-2008, 01:57 PM
And about the watts, do I only get 100 watts going to four speakers? Or do I get 400 watts going to four speakers?
Old 06-14-2008, 03:22 PM
Audio Guy
typically size is 100 watts per channel, although that may be max and not RMS. That's a pretty good bit of power fo non-sub speakers.
