Old 06-12-2008, 08:57 PM
F-Body_Hottie's Avatar
F-Body_Hottie F-Body_Hottie is offline
Send a message via AIM to F-Body_Hottie
Need Help Running Out of Ideas [99 1500 4x4 starts, then stalls]
I have a 1999 Z71 1500 Silverado. recently it has started to give me problems. Every now and then when i go to start it, it starts right up then stalls. It has no problems turning over. If i walk away and leave it alone for like 30 mins it will usually start right up and run great. It also runs through errors in the message center, things such as service 4 wheel drive, low fuel, the battery light, and the security light. I thought it was this aftermarket security system so i disconnected it, but the problem continued, then i thought that i might have a dead cell in the battery, i went and bought a new battery, no fix. I read that improperly connected electric start security systems can cause damage to the computer. I just wanted to get any other advice before i went and bought a computer.
Thanks a bunch,
Kat
Old 06-12-2008, 09:20 PM
Swanny007's Avatar
Swanny007 Swanny007 is offline
Re: Need Help Running Out of Ideas [99 1500 4x4 starts, then stalls]
Are there any trouble codes (is the Check Engine light on)?
My brother-in-law had a GMC about that year. He had starting problems for years, and he'd sit in his truck waiting, etc. Very similar symtoms. He eventually took it to the GM dealership and they flashed the PCM. Problem solved.
If there are no DTC's you might want to bite the bullet and take it to the pros. Otherwise give us the codes or look at REMOVED BY MODERATOR
Old 06-12-2008, 09:27 PM
Nope, the service engine light hasnt come on in years, the ABS is on but i figured i had a bad sensor somewhere and was not to worried about that, i can pick a used computer for 45 shipped i just dont want to spend money on something that does not need to be replaced. I have not yet took it to a dealership or mechanic, but i most likley will soon
Old 06-14-2008, 11:24 AM
kahjdh's Avatar
kahjdh kahjdh is offline
do an alternator test before you do anything drastic.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 06-16-2008, 06:28 AM
But my Alternator isnt giving me any problems, the truck starts right up, then dies after like 2 secs. I put it on a code reader the other day and nothing came up. It hasnt been acting up the past couple days. It just does it every now and then =[
Old 06-16-2008, 10:35 AM
kahjdh's Avatar
Sounds like a computer, bummer
Current Cars:
Past Cars:
Old 06-18-2008, 12:42 AM
rockwood84 rockwood84 is offline
check the throttle body for build up on the plate or worn plate guides, clean the iac ,check the tps and see if it is still in the notch,i've seen the notch key break off and sensor move.
Old 06-19-2008, 08:08 PM
j cAT j cAT is offline
this sounds like empty gas tank or a restricted fuel filter....every 30,000mi replace fuel filter,,,
Old 06-19-2008, 08:12 PM
rhandwor rhandwor is offline
Have you checked fuel pressure the pressure regulator might be on the low side. Origional equipment can be adjusted somewhat.
Old 06-20-2008, 07:39 AM
waitingforcolumbus waitingforcolumbus is offline
My co-workers 99 did this. We read on this forum it could be the fuel pressure regulator. The check was to remove the vacumm line from the regulator and if gas came out of the hose the regulator was bad. Gas dripped out, he replaced the regulator and the truck has started fine since. It's easy and free to check anyway.
Old 06-20-2008, 11:31 PM
a friend of mine had something like that on his '02 silverado 8.1 .it would run fine then it would just die then run fine. we found out later that this was the cranksensor and it got to where it would do it more and more.the cranksensor on an 8.1 is pretty rough to get to .what size motor yours have 5.7? his did the security light also and if he let it cool off a little while it would crank and run till the sensor got hot again.also when the sensor first started to act up it didn't set any codes off except a misfire code or idle below threshold. i think the cranksensor was around $95.00 but that 8.1 been burning gas since we put a new cranksensor in. his old cranksensor was cracked on the end .
Old 06-23-2008, 04:46 PM
Thanks abunch guys, ill try the fuel pressure and tommorow ill check my cranksensor. =]
Current Vehicles *2002 Chevrolet z28 Camaro *2000 Chevrolet Camaro *1999 Chevrolet Ext Cab z71 1500 *1993 Chevrolet z28 Camaro
Old 06-24-2008, 09:11 AM
the other componet to check is the resistance of the ECT sensor cold...then when engine is hot....if the resistance is incorrect it may tell computer that the engine is hot when the engine is cold and this will cause your problem as the injectors will not be turned on long enough to allow sufficient gas to flow ..common problem...
Old 06-29-2008, 07:39 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
when you install the remote start system, OEM security passlock system supposed to be disaBLED. THERE'S A SPECIFIC PROCEDURE FOR THIS, OR THE SECURITY SYSTEM CAN DECIDE SHUTTING DOWN VITAL SYSTEMS TO "PREVENT THEFT".
sorry, my finger slipped and hit caps, but it sort of looks good, so i let it be. my typing speed is horrible. lazy am i.
anyways, try this:
*****, i asked your question in some other places. so far, i had one answer: try "relearn" process. they said to insert the key in, turn the accessories on, let the security light do what it does, and try to start the engine. if it starts and dies, just let it sit like this, without removing the key or doing anything else, for as long as it takes for the light to reflash and go away. they said it might take up to 30 minutes for ecu to relearn the situation.
also this might help:
http://chevroletforum.com/m_1839/tm.htm
a chevy is a chevy, should be the same for any car.
Old 06-29-2008, 07:52 PM
crash_1333 crash_1333 is offline
try repalcing this part... The Ignitan Controll Moduel cost about $10 4 wires plug in that would also cause your truck do that my dad and my friend had the same prob u r and that was the cause
