Old 06-12-2008, 03:09 PM
ebarrett ebarrett is offline
Post antifreeze loss?
On a weekly basis i've had to add anti freeze, and a couple days after i do, the warning light comes back on. Anyone have the same problem and a possible diognostic? No visible leak, and it smells like its burning off...
Old 06-12-2008, 04:33 PM
inafogg inafogg is offline
Re: antifreeze loss?
hello, you dont say how much but if your adding that often then i'd check all hoses/clamps including radiator cap.hows the oil look?? look at the under side of oil cap.its possible that its evaporating on a hot engine so pressurize system when the thermo is open or drive car until its warmed up then ck as the system will be under pressure.Good Luck!!
Old 06-13-2008, 12:23 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Do you have the 3.8 engine? If so its possible that youre having issues with your upper intake manifold, UIM gaskets, or lower intake manifold gaskets, or even feasibly some combination of those.
There is some information about the problem at the top of the forum, if I find out you have a 3.8 Ill PM some more stuff.
For the time being the above advice is good, especially the checking your oil, you want it to look like oil, not chocolate milky at all. Might check under the cap too for any strange deposits.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-25-2008, 10:19 PM
skid marx skid marx is offline
I am having the same problem with my 02. I believe it is the waterpump leaking around the bearing. This is hard to detect because the antifreeze drys up very quickly. Check your waterpump bearing by turning the waterpump by hand. I have had this problem on other vehicles and it has been the waterpump. I am a little nervous about taking it to a garage. The last time I had a waterpump changed at a shop was on my 99. They overheated the engine several times and it started burning oil and was noisey in cold weather after that.
Old 07-04-2008, 03:55 PM
Jimmy Olsen Jimmy Olsen is offline
Add a bottle of "Bars Leaks" and drive the car for 30 minutes with the heater on high. If the water pump is going bad on you, you should see some coolant on the ground after the car has been idling for a few minutes.
1995 Dodge Ram 1500, 143k miles
1999 Oldsmobile Intrigue, 121k miles
2006 Subaru Forester, 68k miles
Old 07-07-2008, 01:48 AM
Yaostevo Yaostevo is offline
I had this problem. I had my water pump replaced and haven't had any problems since.
