Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-12-2008, 11:03 AM
thebrug thebrug is offline
2000 Bonneville trunk release
My trunk release won't work on my 2000 Bonneville. I checked the relay in the fuse box and it is good. Any other ideas.
thanks
Old 06-12-2008, 02:54 PM
maxwedge maxwedge is offline
A990 racer
Re: 2000 Bonneville trunk release
Try checking for continuity across the switch, connections in the trunk.
Old 06-24-2008, 05:25 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Have you tried from both the remote and the switch? Unplug the connector at the actuator in the truck and put a testlight across it from one terminal to the other (ground wire on one and test prob on the other, hit the switch and try it from the remote, if it lights up from both you need an actuator. If not you have a wiring problem
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
