Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-12-2008, 02:27 AM
$ilv3rado's Avatar
$ilv3rado $ilv3rado is offline
Question Help, car jerks/rocks when accelerating
It seems when I accelerate or hold the gas down just a little while trying to maintain a certain speed (or cruise control is on), the car will kind of rock a bit. It's not terrible but definitely noticeable. I was thinking this might be due to a bad motor mount(s). I replaced the top one not too long ago but I'm thinking maybe there's another that needs to be replaced. Does anyone know of a good/easy way of checking the mounts to see which one needs replaced the worst? I was also thinking that it could be some kind of fuel injection problem? It's the most noticeable from 5mph~50mph. Your comments/suggestions would be greatly appreciated. Thanks.
1994 Saturn SL2 DOHC
Old 06-12-2008, 09:42 AM
Cat Fuzz Cat Fuzz is offline
Re: Help, car jerks/rocks when accelerating
Classic defective EGR valve. Pull the vacuum line off the EGR valve and plug the line. Then drive it. If you notice the problem goes away, replace the EGR valve.
Old 06-12-2008, 07:31 PM
RC1488 RC1488 is offline
+1^^^^^^^^^^^^^^^^^^
Your top motor mount is bad regardless. Its over 10 yrs old. Time for a new one
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 06-13-2008, 12:48 AM
And, it's about the easiest thing to do ever on a car.
Old 06-13-2008, 12:51 AM
$ilv3rado's Avatar
Thanks. I pulled it off/plugged line and it did seem to help but I'll have to drive it around a little more to know for sure if that is the problem for sure. Does it hurt anything by driving it around with the EGR line off for a little while? Say a trip to town and back?
I replaced the top motor mount about 7 months ago...but I'm sure the others need it as well.
Old 06-13-2008, 10:10 PM
Readdddddd:
Additional TAM requirements when replacing any of its four components When changing any of the four components of the TAM (((>Torque Axis Mount<))) the following should be stressed.
Attached and supporting the Engine Strut, often overlooked, is a bracket in which one end of the strut sits. This bracket, upon close examination, is afixed to the engine cradle. However, it is attached with two bolts/fasteners. The nuts can be reached only from underneath the cradle.
These two nuts, should be loosened after any work is done on any of the TAM's four components. Therefore, after replacing either the (upper) Engine Mount, the (lower) Transmission Mount, the Transmission Strut, and/or the Strut-to-Engine, it is important to loosen these two nuts/fasterns and then re-torquing (Spell ?)them .
This effort accomplishes the removal any "fore/aft preload" from the Engine Strut.
Torque = 37 ft lbs.
-Luke-
Old 06-14-2008, 12:52 AM
$ilv3rado's Avatar
Readdddddd:
Torque = 37 ft lbs.
-Luke-
I'm almost positive I did this but I will loosen them again and re-torque. Maybe I didn't loosen them enough the first time...We are talking about the two nuts under the passenger's side of the engine that are accessible through two holes..?
The jerking seems the most noticeable in the 40~50mph range. My "Service Engine Soon" light came on after disconnecting/plugging the vacuum hose from the EGR valve. Not sure if this can really cause any damage but I will try it again soon.
Old 06-14-2008, 01:45 AM
Disconnecting the EGR valve for a few days won't do any damage.
Old 06-15-2008, 11:08 PM
$ilv3rado's Avatar
Well, I've driven it for a while with the vacuum line off and it seems like it helps but doesn't totally eliminate the problem...is this possible or am I just thinking it's helping? I mean, it seems to be smoother in cruise control but you can still feel a slight rock when accelerating a bit. If disconnecting the vacuum line is supposed to completely eliminate the rock then I guess I can rule out the valve...If it's not that EGR valve though, then would a bad motor mount(s) be the next suspect?
Old 07-06-2008, 11:30 PM
$ilv3rado's Avatar
Never mind. About ~$75 later this did indeed fix the problem. Thanks again for your help.
Old 07-07-2008, 06:20 AM
Glad you got it fixed!
