Old 03-07-2003, 10:58 AM
djmr2's Avatar
djmr2 djmr2 is offline
Dremel... what is needed?
Hey guys
i think i'm going to get a dremel, i think they're pretty useful and i want to get one because i can't think of any other way to sand down the nub on fujimi wheels where u stick the peg in so i can convert them to fit tamiya wheels..
so what should i get for my dremel? sanding discs? cutting discs?
Old 03-07-2003, 11:03 AM
espin espin is offline
Get the $20.00 battery powered one. Plenty of power for doing models. Also get yourself the accessory pack of bits and tools. Thats should be good to get you started. The cut off wheels and round sanding drums are real good.
Craig
Click here for more pics!
Old 03-07-2003, 11:23 AM
flyonthewall's Avatar
Car Mod guy
You usually get a good selection of bits with the sets you can buy. I got one of the top end sets a few years back and the only thing i have purchased for it since are a selection of dental burrs - very useful and this guard...
If you plan on using the cut off discs (i.e ceramic ones) then i suggest getting one of these, those things are leathal!! They are really brittle and break quite easily, on a couple of occasions they have broken up and flew off somewhere, lukily it wasn't my face!
The set I have also has the flexi shaft, i definately recommend getting one. I use for 99% of the jobs, its so much easier to use, gives you more control and you can hold it between your fingers.
You could also consider the Minicraft range - http://www.minicrafttools.com/ I wish i got one of these instead now coz they have a transformer that allows you to slow the speed right down. The Dremels spin far too fast for cutting plastic, you can manage some tasks with them but for very delicate work they are no good and no transformer exists for them.
Old 03-07-2003, 11:27 AM
djmr2's Avatar
man these things are expensive..
i'm thinking i'm going to try a 2speed (5000 and 10000rpm) first and see how that goes, it's cheap, 50CDN, cordless though
i only want it so i can sand the nubs down on the fujimi/aoshima rims.. and i can't think of any otherway to do it...
any one have any ideas?
Old 03-07-2003, 11:33 AM
Go with the dremel. You will be suprised how much you will used for future projects.
Craig
Old 03-07-2003, 11:34 AM
Car Mod guy
The only other thing i can suggest is this but i dont know how good it is????
Old 03-07-2003, 11:39 AM
Vric's Avatar
Vric Vric is offline
Use Dremel brand... no other thing.. I have a cheap one and I hate it.. not enugh power (15000 rpm, but not very powerfull) I have a cordless Dremel that run a 5000rpm and it's better
Old 03-07-2003, 11:56 AM
djmr2's Avatar
Hey guys
what kind of attachment is recommend to grind/sand things down.. like how i want to use it to sand the nub down
thx
Old 03-07-2003, 12:04 PM
Hey guys
thx
this works well:
Craig
Old 03-07-2003, 12:07 PM
Should be all set with this one:
Craig
djmr2's Avatar
that would work but i dont' think it'll work for a wheel
maybe the FACE of a cutting disc would work?
Old 03-07-2003, 12:09 PM
djmr2's Avatar
sweet
i will check out whats available..
going to go now!
Old 03-07-2003, 12:10 PM
I guess...
Craig
Old 03-07-2003, 12:14 PM
Haha the same thing happened to me, but I thought it wa a piece of plastic that flew off. I finally realized (when my dremel wasn't cutting) that it had broke off. Luckily it didn't hit me. I got scared and didn't use it for a while.
Old 03-07-2003, 02:16 PM
Car Mod guy
DJ - for cutting away the poly cap housing on the wheels, i used a steel cutter like item #38176 in the pic.
BTW, i shall need to do that modification again for my Celica so i will do a specific how to on the subject and take some better pics. I'll try to do this 2moro if i get time.
