Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 06-11-2008, 05:34 PM
cmerrick cmerrick is offline
Question Need Photos or Images for Changing Brake/Turn Signal Lamps - 97 Conti
Does anyone have information (diagrams/photos) for changing the brake/turn signal lamps on a 1997 Lincoln Continental?
Thanks!
P.S. Title should be Need instead of New.
Old 06-11-2008, 11:22 PM
Towncar's Avatar
Towncar Towncar is offline
Re: New Photos or Images for Changing Brake/Turn Signal Lamps - 97 Conti
Welcome to the forums..
Your Owners Manual is >> here << but the only lights it details are the headlights
To make matters worse, the only thing I find in your FSM is the Assembly Removal..
..it does however 'tell' about removing the rear trim cover to gain access to the bulb bases.
Tail Lamp Assembly
Removal and Installation
1. From inside luggage compartment, remove lower back panel trim cover.
2. Remove rear lamp sockets from rear lamp body.
3. Remove nuts retaining rear lamp body to lower back panel. Remove rear lamp.
4. To install, reverse Removal procedure.
-Steven
1996 Town Car, Cartier
